Multiple copies of the same module
Current Version: 2.0.2
Released: 2013-10-27
Re: Multiple copies of the same module
I had an error in the en language File.
Knobblywobbly
Post by Knobblywobbly »
Thanks, it's now working.
Why can I only add this mod once? I would like to have 4 or 5 link sections which contain different categories of links. Is this possible?
Each module can be added only once (Except of the coustom modules)
If you create a link, you can select whether the link should be set as a category.
You can then link the move where you want to go there.
Knobblywobbly
That will work perfectly for what I need.
Thanks very much for all your help!
Don't mention it! :)
and sorry for my bad english,I translate it with Google
