Boardlink: http://www.fishing-victoria.com/
n/a
n/a
Google has our site indexed as:
Fishing Victoria Forum • Portal
If you search: https://www.google.com.au/search?q=fishing+victoria
How do we remove the word " • Portal" from the title that appears in Google?
Thanks
Homepage Title *Remove the word "Portal"?
kooljp
kooljp
Re: Homepage Title *Remove the word "Portal"?
3550 views and not one response?
come on members!
come on members!
This part of overall_header.html adds the page title to your forum's title:
Removing the page title part will remove it on all pages though. Something that might fit what you want is this approach:
Open styles/*yourstyle*/template/overall_header.html
Find:
Replace with:
Open portal.php
Find:
Replace with:
<title>{SITENAME} • <!-- IF S_IN_MCP -->{L_MCP} • <!-- ELSEIF S_IN_UCP -->{L_UCP} • <!-- ENDIF -->{PAGE_TITLE}</title>Open styles/*yourstyle*/template/overall_header.html
Find:
<title>{SITENAME} • <!-- IF S_IN_MCP -->{L_MCP} • <!-- ELSEIF S_IN_UCP -->{L_UCP} • <!-- ENDIF -->{PAGE_TITLE}</title>Code: Select all
<title>{SITENAME}<!-- IF S_IN_MCP or S_IN_UCP or PAGE_TITLE --> • <!-- IF S_IN_MCP -->{L_MCP} • <!-- ELSEIF S_IN_UCP -->{L_UCP} • <!-- ENDIF -->{PAGE_TITLE}<!-- ENDIF --></title>Find:
page_header($user->lang['PORTAL']);Code: Select all
page_header();-
kooljp
Thank you!
Is "•" necessary?
there is still an "•" appearing at the end of the title
Is "•" necessary?
If you properly followed my instructions you should no longer see the bullet point. Make sure you refreshed your template cache.
