Hi.. Just installed the portal. everything seems nice and when opening the url to my site, it shows up.
But when I´m trying to access the acp i just get a blank page.
Anyone who has a hint to solve this?
Cant access acp anymore. **Solved**
Re: Cant access acp anymore.
All language files are copied correctly to the language/en/mods/ directory?
Have you checked that the changes in adm/index.php are done and uploaded correctly?
Yes. I´ve copied all the files to the right location, and I restored the files edited back to original, and did the installation again, but still no acp.
Restored my backup of the forum, and the acp works again. Then I edited all the files for the portal localy with dreamweaver. I´m uploading the files now.
I´ll let you know how it goes when its finished and executed the portal install file.
hmmm... same thing happen. Could it be something wrong with the style? I´m currently running subsilver2 as a style?
same thing happens with prosilver style.
I´m pretty shure that I have done all the steps in the installation correctly, cause dont think I´m doing it wrong everytime i redo it
Is it possible to get the modyfied files from somewhere?
My forum is standar 3.0. with pro and subsilver installed.
What kind of editor do you use?
Take a look here: viewtopic.php?f=24&t=556
Or PM me the link to your forum, Admin Testaccount and a FTP access.
I´ve used Adobe Dreamweaver cs3 to edit the files.
I´m restoring the backup of the forum once again, and will pm you the rest.
Thanks for helping.
Thanks for helping.
Had some time today and compared the english lang. files towards the norwegian, and found out that the files wasnt matching, the creator of the norwegian lang. files had also included some codes for a gallery block, and there was many lines that where missing in the translation.
So now i have a workoing ACP again.
Thanks for the help and for a nice portal.
