Portal column styles
Current Version: 2.0.2
Released: 2013-10-27
Crocodile
phpBB.com User: Crocodile442
Post by Crocodile »
The new portal is an excellent piece of work, thanks.
I can't help but notice that the left and right columns use the same style as the center column. Is there a way I can change that because the look of it in Prosilver is way too blue?
I would prefer to have the left and right columns styled as in the left image below.
Image Image
Again, thanks for the new portal.
Re: Portal column styles
open: root/styles/prosilver/template/portal/_block_config.html
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl><dt style="padding: 0px 0px 2px; white-space: nowrap; margin-bottom: 0px; margin-top: 0px;">' -->
<!-- DEFINE $LR_BLOCK_H_L = '<div class="panel bg3"><div class="inner"><span class="corners-top"><span></span></span><h3>' -->
<!-- DEFINE $LR_BLOCK_H_R = '</h3>' -->
They can also see here: knowledge/kb_show.php?id=45
Crocodile
Post by Crocodile »
Perfect! Thanks Archivar.
