Boardlink: http://www.xx-don-xx.com
nothing.just install the portal and the style.
nothing.
Hello,im having a problem installing the acidthech style to the portal.Ive installed it correctly as is says in the instructions
This Guide is written for AcidTech, but it works for AcidTech Blood / AcidTech Green / AcidTech Purple / AcidTech Lime / AcidTech Yellow / AcidTech Tiger also. If you want to use this Guide for ..Blood ..Green..Purple ..Lime or Yellow you just have to replace "AcidTech" with the Name of your Style in this Guide.
to: root/styles/AcidTech/template/portal/*.*
to: root/styles/AcidTech/theme/images/portal/*.*
Then followed
This should help if you're receiving problems after changes to the styles system:
Changes to the templates:
Go to your ACP, choose "Styles -> Templates -> your style", which has been changed and click "refresh" - confirm with "yes".
Changes to the themes:
Go to your ACP, choose "Styles -> Themes -> your style", which has been changed and click "refresh" - confirm with "yes".
Changes to the Imagesets:
Go to your ACP, choose "Styles -> Imagesets -> -> your style", which has been changed and click "refresh" - confirm with "yes".
In the end "ACP -> General" --> purge cache
Now all your changes should appear properly on your site.
Warning: Cannot modify header information - headers already sent by (output started at /homepages/38/d406180336/htdocs/xx-don-xx.com/modded/cache/tpl_acidtech_overall_header.html.php:2) in /homepages/38/d406180336/htdocs/xx-don-xx.com/modded/includes/functions.php on line 2715
Return to the index page
General Error
template->_tpl_load_file(): File ./styles/acidtech/template/portal/modules/announcements_center.html does not exist or is empty
Please notify the board administrator or webmaster
