L.S.
Recently have upgraded board3 on my forum(3.0.10- Proformell ) from version 1.06 to the new 2.0.0b1.
Upgrade went nice but at second sight I noticed something strange ..
When im not logged on the portal displays as it should ..(I'm using Firefox as my webbrowser)
But as soon as i log on something happens to the layout of the portal only..(its not happening on the forum index )
The center blocks are then changing a oversized format pushing the right column out of its frame ???
I've included two screenprints wich show whats happening pretty well ..
Hoping you guys can give me an answer how to solve this ??
The situation when logged out ..all looks ok :
Now logged in ..right column is pushed out of its frame? :
regards:
Henk
center blocks oversize after login ?
Re: center blocks oversize after login ?
I had this problem with the right side block (just Chrome). You can read it here viewtopic.php?f=36&t=5246
It does not normally do that so you must have a code that's affecting it. The only thing I can tell you is to disable the middle blocks/modules 1 by 1 until you find the one that's affecting the size.
Thanks Victory for the suggestion ..but I figured it out ..
The solution was easier solved as expected ..problem was in a oversized image in one of the center blocks .. after changing its size it was back to normal ..
For those having a similar problem, check the size of whatever you've put into any of the center blocks ....
Topic can be put on lock
