Links Block in new window
el_Vindicador
Post by el_Vindicador »
My renquest its easy,...
Some mod to open the links (of Links Blck) in a new window??
thank!!
pd: i just installed the rc1 version....its awesome!!! very happy for the election of this portal!
el_Vindicador
Re: Links Block in new window
if someone need it
in template/portal/blocks/links.html
search
<li><a href="{link.URL}" title="{link.TEXT}>{link.TEXT}</a></li>
and replace with
<li><a href="{link.URL}" title="{link.TEXT}" target="_blank">{link.TEXT}</a></li>
:D
thomas.d
phpBB.de User: thomas.d
phpBB.com User: thomas.d
Post by thomas.d »
el_Vindicador wrote:if someone need it
search
and replace with
:D
Hola,
thanks for your suggestion.
But keep in mind that "Target" is not allowed in XHTML 1.0 Strict what the portal is based on!
Better (and still XHTML 1.0 Strict) is
onclick="window.open(this.href); return false;"
what makes the same but does only work with JavaScript activated.
(viewtopic.php?p=737#p737)
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
JirkaX
Translator
Post by JirkaX »
So in your opinion replacement should be
<li><a href="{link.URL}" title="{link.TEXT}" onclick="window.open(this.href); return false;">{link.TEXT}</a></li>
yes?
Ice
Post by Ice »
That's correct. :)
JirkaX
Translator
Post by JirkaX »
works fine, thanks
el_Vindicador
hola!!
i moded...like my post...and works perfect!!
its wrong?
thomas.d
Post by thomas.d »
el_Vindicador wrote:hola!!
its wrong?
Hi el_Vindicador,
it's not a question of right or wrong and sure your modding works.
The phpBB-Forum is written in compliance with the XHTML 1.0 Strict standard and so is the portal.
In this standard "Target" is not allowed as the user shall decide wether he opens a new window with a click a link.
The workaround with the JavaScript is according to the standard and it does what you intended.
So it would be better to use the Java instead of the "Target".
Thomas
