								Theriddler
		Posts:  11 Joined:  25. August 2011 14:24
						Post
								by Theriddler  27. August 2011 00:31
			Your Portal Version:  1.0.6
Your phpBB Type:  Standard phpBB3
MODs installed:  Yes
Your knowledge:  Beginner
Boardlink:  http://theriddler.byethost4.com/portal.php
I have changed the colors of the colours.css file for the prosilver theme to give the blocks a grey color.
I've searched trough the forum here, looked and searched with google but can't find  a way to make this.
I have changed the prosolver colours.css to give all the portal blocks a grey background
		Posts:  1963 Joined:  19. April 2009 21:34phpBB.de User:  archivarphpBB.com User:  archivarLocation:  Deutschland
						Post
								by archivar  27. August 2011 03:31
They must not change the *. css.
The change in root / styles / prosilver / template / portal / _block_config.html
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl><dt style="padding: 0px 0px 2px; white-space: nowrap; margin-bottom: 0px; margin-top: 0px;">' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl class="icon">' -->
<!-- DEFINE $C_BLOCK_H_R = '</dl></li></ul>' -->
Try the: ine instructions can be found here:
knowledge/kb_show.php?id=45 V.G. archivar sorry for my bad english
								Theriddler
						Post
								by Theriddler  27. August 2011 11:32
			  thank you so much, now i have rounded border, without your help it wasn't possible.
Thank you for the info about the blocks, and your english is fine
best regards.
