Hello, in my sites I use the stable version 1.6.
I am doing a new site and do not know if it is better to use 1.6 or wait until 2.0 becomes stable.
What do you recommend? When will the stable version 2.0 ready?
Thank you.
1.6 stable or wait 2.0 stable?
Re: 1.6 stable or wait 2.0 stable?
View it here and decide for yourself:
viewtopic.php?f=49&t=4572
It may still take place changes.
You can also set up a test board to see what the new portal for benefits.
What's new in version 2 are important but I do not like to use alpha or beta versions on production sites.
However, if the version 2 comes out in 4 months then I should put the 1.6 and hope that the migration to 2 in the future is simple and fairly painless. If you have to wait 1 or 2 months, then patients will not do the customization 2 times.
On the one hand I want to install version 2 but I'm afraid of the security holes, the other would not want to customize the portal twice (once for 1.6 and the second for 2)
Version 2.0.0b1 is safe or has security problems?
p.s. use google translate, sorry
- Sponsor
- phpBB.de User: IXL
- phpBB.com User: IXLUKCOM
I am the same as you. I will wait before going to the new version.
No, stay with v1.6 because this is beta version and have few errors need to be fixed like the following
viewtopic.php?f=49&t=4747
I finally decided to install the 1.6. I modified it as needed to me ... when the stable version 2 will be available we will see what to do
thanks to all
p.s. my site: HardwareTweakers
phpBB3 3.0.9
Board3 Portal 1.0.6
Ajax Tag Board 4 phpbb3 3.0.8
style: skin-lab X-Treme_light modded by me
thanks to all
phpBB3 3.0.9
Board3 Portal 1.0.6
