Boardlink: http://www.colubridae-forum.nl
Nothing
Contacted my hosting provider to get more information and help.
I got the following message from my hosting provider and they requested not to run the script for more than 60 secs
Time: Sat Jul 23 22:17:39 2011 +0200
PID: 8994
Account: *removed this*
Uptime: 65 seconds
Executable:
/usr/bin/php
Command Line (often faked in exploits):
/usr/bin/php /home/colubrid/public_html/portal.php
Network connections by the process (if any):
tcp: 85.12.11.115:60858 -> 94.136.160.111:80
Files open by the process (if any):
/dev/urandom
Memory maps by the process (if any):
It seems the portal is trying to make a connection to the IP-adres 94.136.160.111 (rDNS = 111.n15.rev.ckg.tc). They warned me that this could be a safety leak and advise to set a timeout or a max time of 60 secs for the script to run if an IP- adres is not available.
How can i make this adjustment to the portal?
