The board owner of the site I help manage managed to F*** alot up while trying to install the new version of portal. I am now going through and I have followed the install guide to the T and I am still getting these errors at install process.
Any help would be great.
Board3 Portal
PHP Version: 5.2.17
DBMS: MySQL(i) 5.1.47-community-log
phpBB3 Version: 3.0.8
Removing permission option: a_portal_manage
ERROR: Permission option a_portal_manage does not exist.
Adding new permission option: u_view_portal
ERROR: Permission option u_view_portal already exists.
Adding new permission option: a_manage_portal
ERROR: Permission option a_manage_portal already exists.
Adding a new database table: PORTAL_MODULES_TABLE
ERROR: Database table PORTAL_MODULES_TABLE already exists.
Adding new config variable: board3_enable
ERROR: Config variable board3_enable already exists.
Adding new config variable: board3_left_column
ERROR: Config variable board3_left_column already exists.
Adding new config variable: board3_right_column
ERROR: Config variable board3_right_column already exists.
Adding new config variable: board3_version_check
ERROR: Config variable board3_version_check already exists.
Adding new config variable: board3_forum_index
ERROR: Config variable board3_forum_index already exists.
Adding new config variable: board3_left_column_width
ERROR: Config variable board3_left_column_width already exists.
Adding new config variable: board3_right_column_width
ERROR: Config variable board3_right_column_width already exists.
Adding new config variable: board3_phpbb_menu
ERROR: Config variable board3_phpbb_menu already exists.
Adding new config variable: board3_display_jumpbox
ERROR: Config variable board3_display_jumpbox already exists.
Removing acp module: General settings
ERROR: Module does not exist.
Removing acp module: ACP_PORTAL_NEWS_INFO
Removing acp module: ACP_PORTAL_ANNOUNCEMENTS_INFO
Removing acp module: ACP_PORTAL_WELCOME_INFO
Removing acp module: ACP_PORTAL_RECENT_INFO
Removing acp module: ACP_PORTAL_WORDGRAPH_INFO
Removing acp module: ACP_PORTAL_PAYPAL_INFO
Removing acp module: ACP_PORTAL_ATTACHMENTS_INFO
Removing acp module: ACP_PORTAL_MEMBERS_INFO
Removing acp module: ACP_PORTAL_POLLS_INFO
Removing acp module: ACP_PORTAL_BOTS_INFO
Removing acp module: ACP_PORTAL_POSTER_INFO
Removing acp module: ACP_PORTAL_MINICALENDAR_INFO
Removing acp module: ACP_PORTAL_CUSTOMBLOCK_INFO
Removing acp module: ACP_PORTAL_LINKS_INFO
Removing acp module: ACP_PORTAL_FRIENDS_INFO
Removing acp module: ACP_PORTAL_BIRTHDAYS_INFO
Adding acp module: Portal
ERROR: Module already exists.
Adding acp module: Portal Modules
Adding acp module: Upload module
Converting from Board3 Portal 1.0.6 & adding basic set of modules
SQL ERROR Table 'dropdea2_solobb.solo_portal_modules' doesn't exist
Adding a new column named module_status to table PORTAL_MODULES_TABLE
ERROR: The column module_status already exists on table PORTAL_MODULES_TABLE.
