Moving Blocks from column to column
SliXie
phpBB.de User: SliXie
phpBB.com User: slixie
Post by SliXie »
Your Portal Version: 1.0.6 Engl
Boardlink: http://nerdz-guild.com
I read this knowledge base before FAQ and followed instructions but it didn't seem to work.
I am trying to move user menu, statistics, calendar, the team, and links from the right column to the left column. I followed the instructions given to me on knowledge/kb_show.php?id=11 but being quite new to modifying it is a bit confusing than other read me files i have came across in the site.
If you notice the centre block isn't quite alligned right and only works if i remove the right column. I edited the files in root\styles\prosilver\template\portal\portal_left.html and root\styles\prosilver\template\portal\portal_right.html as well as portal.php as told to me by the instructions but nothing seems to work to have it show on the left column. Is there a better guide in moving blocks from column to column?
I think the problem im coming across is the portal.php i'm not sure where to put the code and whether to delete the old code that states the blocks are on the right column.any help would be greatly appreciated.
