Problem after installation!
Boardlink: http://infamouskillas.net
Nothing
I tried reinstalling AutoMod, didn't work
After installing Board3 Portal, my automod got deleted for some reason and now I don't get how to delete the portal because I installed it using automod. When I delete portal folder from ftp client it shows an error. This is affecting the whole board. I need help, this is urgent!
Nothing
Re: Problem after installation!
Board3 Portal does not modify the AutoMOD modules. What error does it show?
Cannot access AutoMOD
There is no automod module/tab in the admin cp so I can't delete the portal.
When I tried reinstalling automod, it didn't work.
Is there a way to manually delete the portal?
Actually, before deleting it is it possible to fix the portal?
I will post some screenies.
http://i844.photobucket.com/albums/ab8/ ... at/s11.png
http://i844.photobucket.com/albums/ab8/ ... at/s22.png
http://i844.photobucket.com/albums/ab8/ ... at/s33.png
http://i844.photobucket.com/albums/ab8/ ... at/s44.png
http://i844.photobucket.com/albums/ab8/ ... at/s55.png
http://i844.photobucket.com/albums/ab8/ ... at/s66.png
Note that there is no such module as "Portal" or "AutoMOD" in my ACP anymore.
The style you use is not compatible with the Portal as it is not wide enough. The portal modules can be found under the .MODs Tab.
I cant access the .mods tab.
But the main issue is that im not able to access autoMOD and how is it that automod dissapeared right after the portal was installed? automod is one of the main features of phpbb3 because it allows easy installation. What's the point if you don't have it?
General Error
Cannot find module ./../includes/acp/acp_subject_prefix.php-
I already told you. Board3 Portal does not remove AutoMOD.
The block "who is online" does not show.
How to fix this bug?
Board3.de - Rules | We ask for your attentionGalina wrote:The block "who is online" does not show.
Hi,Galina wrote:The block "who is online" does not show.
This has nothing to do with Board3Portal.
Please get phpBB.com.
Please look in the ACP settings -> Server Configuration -> online display of members activate.
