Boardlink: http://www.mst-aviation.nl/phpbb
Nothing
Looking into the code to solve the problem
Hello Guys,
I like the aeroblue theme,
http://board3-styles.de/portal.php?style=3
But the problem is i want to use portalvieuw on the forum page, but the code i need to change i cant find in the aeroblue style. I know portal vieuw is created on the prosilver en subsilver style. But i cant imagine that is it so diffecult to change the same settings in the aeroblue theme so i have my left menu block whem browsing the forum!
Regards
Roel
Aeroblue theme portalvieuw
- phpBB.de User: mstaviation
- phpBB.com User: mstaviation
Re: Aeroblue theme portalvieuw
First of, use the subsilver2 instructions for AeroBlue. When editing overall_header.html, put the code at the end of the file and in overall_footer.html, put the code at the beginning of the file.
thanks problem is solved!Marc wrote:First of, use the subsilver2 instructions for AeroBlue. When editing overall_header.html, put the code at the end of the file and in overall_footer.html, put the code at the beginning of the file.
Xmmm... Ich denke AeroBlue basiert doch auf proSilver Basis. Ich habe AeroBlue ein wenig frisiert und etzt siet es so aus http://lvatu.ru
Ne, es basiert auf subsilver2.
OK Ich gebe dir recht. http://demo.phpbb3styles.net/AeroBlue Hmmm, jetzt verstehe ich warum habe ich Problem mit Änderung gehabt.
