The Team Block Modify
Khamosh-Saya
phpBB.de User: Khamosh-Saya
phpBB.com User: Khamosh-Saya
Post by Khamosh-Saya »
Your Portal Version: 1.0.5
Boardlink: http://www.friendzpoint.com
Nothing
Nothing
Hi All,
I Want to modify The Team Block mean its will show Group wise
like
Developer Team
user 1
User 2
Administrator Team
User 1
User 2
Staff Team
User 1
User 2
Global Moderator
User 1
Moderator
User 1
Something Like This
How Can i??
Re: The Team Block Modify
Have you tried switching the extended Team block on?
Khamosh-Saya
Yea Its Working But i want to Modify with my Style like
1st is Administrator 2nd is Staff Team 3rd is So on
Like this
So you want to change the order of the displayed teams? Well that is unfortunately impossible at the moment.
Khamosh-Saya
Its a good Add on if u will work on it Like Option in ACP to Modify The Team Block
Which Group will 1st and 2nd and 3rd
