Your Portal Version: 1.0.5
my portal is in english and I try to translate in french
I transferred the files to the portal in English to the French language file
Hello everybody,
Sorry if my english is poor, i'm just a frenchy.
I installed the portal but the problem is that the portal is in english and I would like to translate all in French.
Do you have any idea to solve my problem plz
Translation
anywhere91
- Translator
- phpBB.com User: Anywhere91
Re: Translation
Hello / Good evening
Verifies the presence of file in the folder language/fr/mod/lang_portal.php
Best regards
Bonjour / bonsoir
Vérifie la présence du ficher suivant dans le dossier language/fr/mod/lang_portal.php
Cordialement
Best regards
Bonjour / bonsoir
Cordialement
Re: Translation
You can download the French language files here:
viewtopic.php?f=13&t=3329
Re: Translation
that's works, thanks a lot.
