Upgrade phpbb3 1.7 with current version of portal
- phpBB.com User: ReconMarine
Your Portal Version: 1.5
No problem yet
nothing yet
Is there anything in the portal or the portalview that is going to break again if I upgrade to the new phpbb 1.7?
From now on I ask first, before I break stuff
Thanks my friend
Semper Fi
No problem yet
nothing yet
Thanks my friend
Semper Fi
Re: Upgrade phpbb3 1.7 with current version of portal
I think you probably mean phpBB 3.0.7.
Anyhow, I'm currently not aware of any problems with phpBB 3.0.7.
Updated my forum from phpbb3 v. 3.0.6 to 3.0.7, without any problems. Portal v1.0.5, portalview v1.0.0RC3 and all my mods still works.
I updated my forum to 3.0.7-PL1 and my portal wont work at all, nor will the mods tab in my ACP.
You dont tell what version you upgrade from, but after the upgrade you need to edit the files with the needed mod codes, or reinstall your mods if you use Auto Mod
It would also be great to know how you updated? Did you use the automatic updater?
I updated from 3.0.6 to 3.0.7 and everything was working great for a few days, then I updated to 3.0.7-PL1 and it doesn't work..
yes i used the automatic updater
so I have to re-edit all the files again?
No, you only need to edit the "include/constants.phpdylanlegit wrote:so I have to re-edit all the files again?
The portal need
define('PORTAL_CONFIG_TABLE', $table_prefix . 'portal_config');
You add it so it be like
// Additional tables
Check all file edits the portal needs.
Thanks. Hope it will work for me.
Being stressed out and overweight may not be YOUR fault! It's true, a mysterious condition might be to blame. An estimated 70-80% are suffering from this condition, and don't even know it!
http://www.howtocurecandida.com/survey/
