Updating from 1.0.2 to 1.0.5
andrew55
Post by andrew55 »
Your Portal Version: 1.0.2
No problem yet. I'm just trying to figure out what steps to take to update from 1.0.2 to 1.0.5. I saw in the download there were update versions, such as update_010_to_103. I didn't see the one I need. I wasn't sure if I need to do two or three of them to make it to the most current version. Thank you for any suggestions.
I searched the forum, but couldn't find and answer.
Wasn't sure if this is where message goes. I'll repeat it - I'm just trying to figure out what steps to take to update from 1.0.2 to 1.0.5. I saw in the download there were update versions, such as update_010_to_103. I didn't see the one I need. I wasn't sure if I need to do two or three of them to make it to the most current version. Thank your for any suggestions.
Re: Updating from 1.0.2 to 1.0.5
Open the folder update_010_to_103. There you will find the update instructions from 1.0.2 to 1.0.3. After that, go back to the contrib-folder and open the update_103_to_105 folder. There you will find the update instructions for updating 1.0.3 to 1.0.5.
andrew55
Post by andrew55 »
Marc - Thanks for the instructions. Would it be safe to just save over all of the existing mod files with the newest version and then do the edits from the two pages you mentioned?
You mean you want to overwrite all portal files and then just do the mentioned edits? Yes, that will work.
andrew55
Post by andrew55 »
Great - thanks for the help. I guess it's off to editing!
