how to implement in 3.0.6
exhale
phpBB.de User: exhale
phpBB.com User: exhale.DE
Post by exhale »
Your Portal Version:
Boardlink: http://www.hessenfeierei.de
i deleted all my phpBB server files, backupped the things i wanted to keep and then uploaded clean 3.0.6 phpbb files, after that, i uploaded all the portal files to the root dir and started editing
deleted, copied and pasted around (:
files to edit: session.php
		if (!empty($_GET['style']) && $auth->acl_get('a_styles'))
should be replaced with
		if (!empty($_GET['style']))
but my session.php looks like this at this place:
		if (!empty($_GET['style']) && $auth->acl_get('a_styles') && !defined('ADMIN_START'))
what to do?[/i]
Re: how to implement in 3.0.6
For now, just do the same thing.
exhale
Post by exhale »
Parse error: syntax error, unexpected T_BOOLEAN_AND in /usr/export/www/vhosts/funnetwork/hosting/hessenfeierei/phpBB3/includes/session.php on line 1574
I meant replace the whole line.
Find:
Replace with:
