Boardlink: http://www.solid-gaming.com
nothing
remove the image
people using IE are seeing this and i cant seem to get rid of it take a look
Black Smoke Style BANNER ERROR
Re: Black Smoke Style BANNER ERROR
<a href="./index.php?sid=923c3e9f289b06436f47021c808e23cb" title="Board index" id="logo"><img src="./styles/BlackSmoke/imageset/logo.png" width="281" height="69" alt="" title="" /></a>
Moving to "General phpBB3 Support" as this has nothing to do with the portal. Please read the board rules before posting.
- phpBB.de User: blast
- phpBB.com User: blast
First things first.... I read the rules i assume this was a styles issue so i came to "styles support" ... makes since to post here since i was having a styles issue in the overall_header.html .... correct me if I'm wrong but i don't see where i was at fault
its not a style "error" the style works as needed yours is general assistance due to you editing it to your own style....
I think your Header Image is missing... Check your ACP-> style-> imageset... there you can set the Headerimage
well the banner is two images the one thats causing the error is called logo somthing and i removed it but seems like the files or script is still trying to pull an image or somthing
Browse to your ACP -> styles -> imagesets -> blacksmoke -> edit
There you can select image: "main logo"
Beneath on "image" choose "no image"
this should solve it...
- phpBB.de User: mycat1102
- phpBB.com User: mycat1102
It's great !
mycat1102
mycat1102
