Your Portal Version: 1.0.3
Is it possible to determine what search engines show up in the pull down menu in the search block?
[SOLVED] Edit search engines in portal block?
Re: Edit search engines in portal block?
You will need to edit this part of styles/*yourstyle*/template/portal/block/search.html:
case 'wikipedia':
window.open('http://en.wikipedia.org/wiki/Spezial:Search?search=' + qs_keywords, '_wikipedia', '');
return false;
case 'google':
window.open('http://www.google.com/search?q=' + qs_keywords, '_google', '');
return false;
case 'yahoo':
window.open('http://search.yahoo.com/search?p=' + qs_keywords, '_yahoo', '');
return false;
case 'msnlive':
window.open('http://search.live.com/results.aspx?q=' + qs_keywords, '_msnlive', '');
return false;
case 'altavista':
window.open('http://www.altavista.com/web/results?itag=ody&q=' + qs_keywords + '&kgs=0&kls=0', '_altavista', '');
return false;
case 'lycos':
window.open('http://search.lycos.com/?query=' + qs_keywords, '_lycos', '');
return false;
case 'odp':
window.open('http://search.dmoz.org/cgi-bin/search?search=' + qs_keywords, '_odp', '');
return false;
Cool, thanks!
I was looking at the root/portal/block/search.html file...
I also took out this bit;
<option value="google" style="background-color: #FEF2D6;">Google</option>
<option value="yahoo" style="background-color: #FEF2D6;">Yahoo</option>
etc..
