1.how can i put custom right block, when i go to ACP and portal part, i have "Custom blocks settings for the small block and for center" and when i put here my code always is left but i want to be on left . Portal looks ugly when everything goes on left side.
And one more qustion:
2.I put a unique counter but i want to be on portal
I have this files counter.php and totorial said this
UPLOAD ALL THE FILES INTO YOUR HOME DIRECTORY.
CHOMD 777 ALL TEXT FILES.
ADD THE FOLLOWING CODE INTO YOUR WEBPAGE
<?php include "counter.php"; ?>
CHANGE THE EXTENSION OF YOUR WEBPAGE FROM .HTML OR .HTM TO .PHP
WEBPAGE AND COUNTER.PHP SHOULD BE IN THE SAME DIRECTORY
TO SEE THE STATISTICS USE THE FOLLOWING URL
HTTP://www.yourserver.com/counter.php?action=stats
Thats All ;)
BTW I have Aero blue style.
Thanks for help[/i]
