SOLVED - install.php give a blank page
Sfullak
Post by Sfullak »
Your Portal Version: Fresh
Boardlink: http://www.magenealogie.net/fofo/
PHP Version: PHP Version 4.4.9-1.standard
MySQL Version: 5.0.51a-3ubuntu5.4-log
Try to install the mode dl on phpbb.com (1.0.2) :
Modification of files on local disk
Up Load requested files (who comes with the archive, not the local file I have modified) on website
Going on adress http://www.magenealogie.net/fofo/instal ... nstall.php as requested by instructions
=> Give a blank page
Cheking db for new tables: no new table
Nothing, prefer to wait from instructions from you
Installation is stopped as http://www.magenealogie.net/fofo/instal ... nstall.php give a blank page.
PS Sorry for my poor english.
Re: install.php give a blank page
Use our latest release instead ;)
viewtopic.php?style=3&f=40&t=2784
Sfullak
Post by Sfullak »
OK, I shoul use the latest one, but why the latest one is not on phpbb.com ?
(and thanks for your very quick answer)
Because of the slow validation process... ;)
Sfullak
Post by Sfullak »
OK,
I should came back to you, if it does'nt work or if it's works well.
Thanks,
Sfullak
Post by Sfullak »
Same trouble with the latest version when I go on http://www.magenealogie.net/fofo/install/index.php
My Board is stopped as there is a install directory.
Change: I modify the name of install directory to installe, that my board should work during waiting answers, so the link of the page is http://www.magenealogie.net/fofo/installe/index.php
did you modified any files in your install folder?
Sfullak
Post by Sfullak »
No, they are same as in the archive I have downloaded.
This is the source of the page:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META content="text/html; charset=windows-1252" http-equiv=Content-Type></HEAD>
<BODY></BODY></HTML>
Very strange...
This code is generated by the Browser if he gets a blank Page from the Server.
Clear all portal related files, and clear all your caches and try it again...
Your Board is working, so your php settings are ok.
This error occurs if you have any free space in your php file bevor the <?php... or after ?>. But if you dont change the files... :?
Did you upload the files in automode, ascii or binary? (ftp) (should be auto)
Sfullak
Post by Sfullak »
I gave deleted my directory "installe"
I have made a new transfer in the directory "install" in auto mode: same
I tried in Binary: files are not good so I make a new clean and a new transfer in automode : same
I have re downloaded the zip pacjkage and re made transfer
I check and no space before <?php and no space after ?>
Note that I have only deleted files only in install directory (that I have rename, after my tests in "installe" to make my board working).
Same blank page with the code
<HTML><HEAD>
Is there other filse to check in other directory ?
open your config.php and find these lines:
// @define('DEBUG', true);
// @define('DEBUG_EXTRA', true);
replace it with:
This will activate the debug mode. If you now open your install/index.php you probably get an errormessage.
Sfullak
Post by Sfullak »
Here are the errors:
[phpBB Debug] PHP Notice: in file common.php on line 877: Undefined index: LOG_DELETE_TOPIC
[phpBB Debug] PHP Notice: in file session.php on line 2030: set_lang() [function.set-lang]: Unable to access ./../language/fr/mods/install_portal.php
[phpBB Debug] PHP Notice: in file session.php on line 2030: set_lang(./../language/fr/mods/install_portal.php) [function.set-lang]: failed to open stream: Success
Fatal error: set_lang() [function.require]: Failed opening required './../language/fr/mods/install_portal.php' (include_path='.:/include/') in session.php on line 2030
Note that I have not transferred the files I have modified on local.
As I see it is a language trouble and when I switch my profile to English, seems to works: It ask me "Prior to running the installation script, you need to upload the edited files, especially /includes/constants.php."
I should see next tomorow morning, as the board is very important in the evening.
Then upload all your files, make the edits as described in install.xml and run the installer. After that, you can change back your language to french. ;)
Sfullak
Post by Sfullak »
Me Again, Installation made the tabbles but stop after with error:
General Error
SQL ERROR [ mysql4 ]
Duplicate entry '4-118' for key 1 [1062]
SQL
INSERT INTO fofo_acl_roles_data (role_id, auth_option_id, auth_setting) VALUES (4, '118', 1)
BACKTRACE
FILE: includes/db/mysql.php
LINE: 174
CALL: dbal_mysql->sql_error()
FILE: install/install_install.php
LINE: 238
CALL: dbal_mysql->sql_query()
LINE: 73
CALL: install_install->load_schema()
FILE: install/index.php
LINE: 279
CALL: install_install->main()
LINE: 56
CALL: module->load()
Ohhh K! Since im unfamiliar with SQL i cannot help you here... But im sure, there will be someone else who can ;)
