Boardlink: http://www.friendzpoint.com
Newly Install Everything
Nothing
Mine Friend Install Everything
Hi Dears,
i have seen on other board thats The Block Corners are Round like its look By Default Temoplate Block.
Something wrong in mine forum...
Portal Block Borders
- phpBB.de User: Khamosh-Saya
- phpBB.com User: Khamosh-Saya
Re: Portal Block Borders
Maybe that will help you:
viewtopic.php?f=38&t=1899
Thank arc for quick reply
i tried it. i checked mine files. That was already edited.
so i just upload root folder. and after that try to purge the cache. it give me error
General Error
Could not open ./../styles/AeroGreen/template/colour_swatch.html
I Trid to find out this file but i cant....
General Error
Waiting for responce
I'm having the same problem
Sorry, I can't help you further, please check the styles forums if you can.
Sorry for again
Did u find any solution?
i update portal to 1.0.4
As i can see, you are on the right path... Just take the block_config you requested, and you will have your rounded corners
u mean i will wait for That file?
