need help with pbwow Style
Matt-One
Post by Matt-One »
Your Portal Version: 1.0.2
Boardlink: http://aitwow.altervista.org
nothing
trying to change some colour in portal.css with no luck :/
Hello, this is my first post, i want to know how to change the color text of my portal ALL IS BLACK, and if u see in the central box LATEST NEWS u can see what is write in only by highlight with the mouse. Also if u see Menu (on the left) all the text are Black... u can see only the link :/ ...I use IE8 with wista... i don't know if there is some incompatibility with this new browser :/
so, what file i have to check to change the color?? i have tryed to install porta 1.0.3 but is the same problem.
MANY THANKS.
Re: Black Text in my portal.How to change?
What style are you using? Is it based prosilver or subsilver2?
Did you refresh your theme cache?
Matt-One
Post by Matt-One »
Marc wrote:What style are you using? Is it based prosilver or subsilver2?
it's a theme downloaded from pbwow but it prosilver based. yes i have refreshed theme cache :/
p.s.
yesterday i have tryed portal 1.0.3 and one of my friend (using another browser not IE, i have forget to ask him what browser) see all correctly.ì with no highlight.
First - You should use 1.0.3
Second - You need an adaption for this Style. Your portal looks like topsy-turvy ;)
I tryed to install this too, but now is saw this on the Authors topic:
Warning! PBWoW is not for rookies. This stuff isn't 1-2-3-presto!
It is one of the hardest styles to set up properly you will probably ever see. PBWoW is currently in a release candidate stage. You can use it on a live phpBB board but we cannot guarantee a bug free experience. Board features may be broken and my source code modifications have not been thoroughly tested for security vulnerabilities. Make a backup of all your files before installing PBWoW.
Matt-One
Post by Matt-One »
Mike wrote:First - You should use 1.0.3
Yes but also with 1.0.3 the problem is the same... however it's not very hard to install only the styles in the forum...the problem is the portal :P
I try to make a config file for you. ;)
But since it is new on 1.0.3 you have to install it ;)
Moved to Style Support.
Matt-One
Post by Matt-One »
Mike wrote:I try to make a config file for you. ;)
thanks m8, im a noob to making site and similar i have only some base on html...no problem for the 1.0.3 i will install it tonight after the work :) thanks for your patience...but..when u create the config file u have to tell me what i have to do whit this file :) many thanks...
Matt-One
Post by Matt-One »
portal 1.0.3 correctly installed :)
Return to “Styles Support”
