Can't find some code in Overall_header.html
GWAVE 23 xDoWx
phpBB.com User: GWAVE 23 xDoWx
Post by GWAVE 23 xDoWx »
Your Portal Version: 1.0.3
Boardlink: http://xdowx.co.uk/forums
Hi.
I used the older version of the BoardPortal and I had the same problem. I am having some trouble with finding some of the code that is in the instructions. The theme I am using is based on "subsilver2" so I am following those instructions.
I can't find any of the code in my overall_header.html that is instructed to find in the install instructions.
Here is my overall_header.html
<head>
<meta name="copyright" content="2002-2006 phpBB Group" />
{META}
<style type="text/css">
/*Credits: CSSplay */
/*URL: http://www.cssplay.co.uk/menus/pro_drop2 */
.preload2 {background: url(prodrop2/button4.gif);}
.menu2 {padding:0 0 0 32px; margin:0; list-style:none; height:40px; background:#fff url({T_THEME_PATH}/images/button1a.gif) repeat-x; position:relative; font-family:arial, verdana, sans-serif; }
.menu2 li.top {display:block; float:left; position:relative;}
.menu2 li a.top_link {display:block; float:left; height:40px; line-height:33px; color:#bbb; text-decoration:none; font-size:11px; font-weight:bold; padding:0 0 0 12px; cursor:pointer;}
.menu2 li a.top_link span {float:left; display:block; padding:0 24px 0 12px; height:40px;}
.menu2 li a.top_link span.down {float:left; display:block; padding:0 24px 0 12px; height:40px; background:url({T_THEME_PATH}/images/down.gif) no-repeat right top;}
.menu2 li a.top_link:hover {color:#fff; background: url({T_THEME_PATH}/images/button4.gif) no-repeat;}
.menu2 li a.top_link:hover span {background:url({T_THEME_PATH}/images/button4.gif) no-repeat right top;}
.menu2 li a.top_link:hover span.down {background:url({T_THEME_PATH}/images/button4a.gif) no-repeat right top;}
.menu2 li:hover > a.top_link {color:#fff; background: url({T_THEME_PATH}/images/button4.gif) no-repeat;}
.menu2 li:hover > a.top_link span {background:url({T_THEME_PATH}/images/button4.gif) no-repeat right top;}
.menu2 li:hover > a.top_link span.down {background:url({T_THEME_PATH}/images/button4a.gif) no-repeat right top;}
.menu2 table {border-collapse:collapse; width:0; height:0; position:absolute; top:0; left:0;}
/* Default link styling */
/* Style the list OR link hover. Depends on which browser is used */
.menu2 a:hover {visibility:visible;}
.menu2 li:hover {position:relative; z-index:200;}
/* keep the 'next' level invisible by placing it off screen. */
.menu2 ul,
.menu2 :hover ul ul,
.menu2 :hover ul :hover ul ul,
.menu2 :hover ul :hover ul :hover ul ul,
.menu2 :hover ul :hover ul :hover ul :hover ul ul {position:absolute; left:-9999px; top:-9999px; width:0; height:0; margin:0; padding:0; list-style:none;}
.menu2 :hover ul.sub {left:2px; top:40px; background: #fff; padding:3px 0; border:1px solid #4ab; white-space:nowrap; width:93px; height:auto;}
.menu2 :hover ul.sub li {display:block; height:20px; position:relative; float:left; width:90px;}
.menu2 :hover ul.sub li a {display:block; font-size:11px; height:20px; width:87px; line-height:20px; text-indent:5px; color:#000; text-decoration:none; border:3px solid #fff; border-width:0 0 0 3px;}
.menu2 :hover ul.sub li a.fly {background:#fff url({T_THEME_PATH}/images/arrow.gif) 80px 7px no-repeat;}
.menu2 :hover ul.sub li a:hover {background:#4ab; color:#fff;}
.menu2 :hover ul.sub li a.fly:hover {background:#4ab url({T_THEME_PATH}/images/arrow_over.gif) 80px 7px no-repeat; color:#fff;}
.menu2 :hover ul li:hover > a.fly {background:#4ab url({T_THEME_PATH}/images/arrow_over.gif) 80px 7px no-repeat; color:#fff;}
.menu2 :hover ul :hover ul,
.menu2 :hover ul :hover ul :hover ul,
.menu2 :hover ul :hover ul :hover ul :hover ul,
.menu2 :hover ul :hover ul :hover ul :hover ul :hover ul
{left:90px; top:-4px; background: #fff; padding:3px 0; border:1px solid #4ab; white-space:nowrap; width:93px; z-index:200; height:auto;}
</style>
// <![CDATA[
<!-- IF S_USER_PM_POPUP -->
	if ({S_NEW_PM})
	if (!name)
		name = '_popup';
	return false;
function jumpto()
	var perpage = '{PER_PAGE}';
* Find a member
function find_username(url)
	return false;
* Mark/unmark checklist
	if (!parent)
	if (!parent)
		return;
			rb[r].checked = state;
<!-- IF ._file -->
	function play_qt_file(obj)
		if (rectangle)
			var width = 200;
			var height = 0;
		obj.width = width;
		obj.height = height + 16;
		obj.Play();
</script>
</head>
<a name="top"></a>
<center>
<div id="wrap">
	<div id="brd_outer">
	<div id="brd_in">
        <a href="{U_PORTAL}"><img src="{T_THEME_PATH}/images/banner.png" width="940" height="250" alt="Dogs Of War- Doing It Doggy Style" /></a>
<span class="preload2"></span>
<ul class="menu2">
	<li class="top"><a href="{U_INDEX}" id="home" class="top_link"><span>{L_INDEX}</span></a></li>
	<li class="top"><a href="{U_PROFILE}" id="products" class="top_link"><span class="down">Control Panel</span><!--[if gte IE 7]><!--></a><!--<![endif]-->
	<li class="top"><a href="" id="services" class="top_link"><span class="down">Search Post</span><!--[if gte IE 7]><!--></a><!--<![endif]-->
		<!--[if lte IE 6]><table><tr><td><![endif]-->
		<ul class="sub">
			<li><a href="{U_SEARCH_SELF}">My Post</a></li>
			<li><a href="{U_SEARCH_UNANSWERED}">Unanswered</a></li>
			<li><a href="{U_SEARCH_NEW}">New Post</a></li>
			<li><a href="{U_SEARCH_ACTIVE_TOPICS}">Active Post</a></li>
		<!--[if lte IE 6]></td></tr></table></a><![endif]-->
	</li>
	<li class="top"><a href="{U_MEMBERLIST}" id="contacts" class="top_link"><span class="down">{L_MEMBERLIST}</span><!--[if gte IE 7]><!--></a><!--<![endif]-->
		<li class="top"><a href="{U_FAQ}" id="shop" class="top_link"><span class="down">{L_FAQ}</span><!--[if gte IE 7]><!--></a><!--<![endif]--><!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED -->
	<li class="top"><a href="{U_REGISTER}" id="privacy" class="top_link"><span>{L_REGISTER}</span></a></li><!-- ENDIF -->
<!-- IF not S_IS_BOT -->
	<!-- IF S_USER_LOGGED_IN -->
			<!-- IF S_DISPLAY_PM --><li class="top"><a href="{U_PRIVATEMSGS}" id="home" class="top_link"><span>{PRIVATE_MESSAGE_INFO}</span></a></li><!-- ENDIF --><!-- ENDIF --><!-- ENDIF -->
        <!-- IF not S_IS_BOT --><li class="top"><a href="{U_LOGIN_LOGOUT}" id="home" class="top_link"><span>{L_LOGIN_LOGOUT}</span></a></li><!-- ENDIF -->
        <div id="hdr"><div id="hdr_ls">
	</div></div>
	<div id="nav_btm"></div>
	<div id="nav_shadow"></div>
	<div id="menubar">
			<td class="genmed">
				<!-- IF S_USER_LOGGED_IN -->{LAST_VISIT_DATE}<!-- ENDIF -->
			<td class="genmed" align="right">{CURRENT_TIME}</td>
<div id="wrapcentre">
	<br style="clear: both;" />
	<!-- INCLUDE announcement_centre.html -->
Please help. Thank you.[/i]
~HG~
Re: Can't find some code in Overall_header.html
Post by ~HG~ »
The edits to the overall_header.html is adding a link to the portal only.
You can place this link just about anywhere that suits your board.
I suggest you post it before Board index and in the same format that the current .html has the menu links listed.
GWAVE 23 xDoWx
Ok Thanks but im still not sure where to put it
Make a copy of your overall_header first, and then try this code:
<head>
{META}
.menu2 ul,
</style>
// <![CDATA[
	if ({S_NEW_PM})
	if (!name)
		name = '_popup';
	return false;
function jumpto()
* Find a member
	return false;
	if (!parent)
	if (!parent)
		return;
<!-- IF ._file -->
		if (rectangle)
			var width = 200;
			var height = 0;
		obj.width = width;
		obj.Play();
</script>
</head>
<a name="top"></a>
<center>
<div id="wrap">
	<div id="brd_in">
        <a href="{U_INDEX}"><img src="{T_THEME_PATH}/images/banner.png" width="940" height="250" alt="Welcome To TranceSounds: No.1 Place For Live Radio Sets" /></a>
<ul class="menu2">
	<!-- IF U_PORTAL --><li class="top"><a href="{U_PORTAL}" id="portal" class="top_link"><span>{L_PORTAL}</span></a></li> <!-- ENDIF -->
		<ul class="sub">
	</li>
	</div></div>
	<div id="menubar">
			<td class="genmed">
Now you can turn on/off the Headermenu in your ACP + have a Link to your Portal at this Menu.
Note that this style is for phpBB 3.0.2 only, and not recommended for use.
GWAVE 23 xDoWx
Its working now. Thanks alot mate
Return to “Styles Support”
