Upgrade 103 Block Question
DragonMaster
phpBB.com User: DragonMaster1
Post by DragonMaster »
I have about 6 extra blocks added to my 102 install
Do I need to install a base 103 and then re-add the additional blocks?
Will this require the SQL that a couple of them had to be removed and also re-added?
Re: Upgrade 103 Block Question
DragonMaster wrote:Do I need to install a base 103 and then re-add the additional blocks?
In general: Yes.
See this topic for informations, how to do it best, to get updates easier done in future:
viewtopic.php?f=9&t=1851
DragonMaster wrote:Will this require the SQL that a couple of them had to be removed and also re-added?
No, normally there is nothing to be done with SQL (regarding additional blocks).
