I'm thinking about installing your portal mod and was wondering if I could install it successfully if I'm using the twilightbb theme?
Using PHPBB 3.04.
Thanks.
Pre-Install Questions
Re: Pre-Install Questions
What is your Question?
Just install your Board using the subsilver2 install guide. If you have trouble, ask a precise question
- phpBB.de User: webslug
- phpBB.com User: webslug
The instructions looks clear however I was looking at the part to edit the theme.
It says you should edit your overall_header.html and seek the following line
However using the TwilightBB theme I don't have this line?
Just skip this part of installation guide. This is only to hide the Navbar in your Portal. But in my opinion the twilightbb without the Nabvar looks weird...
The only thing you should add in the Header is the Portal Link as described in the xml.
Thanks Mike,
Which folder should I copy into styles/twilightbb?
The contents of root/prosilver or root/subsilver 2?
I don't know what my theme is based on. How do I find out?
Also should I expect any graphical problems? Is the Portal generally compatible with most themes?
I've modified all the files, I couldn't perform many of the last steps involving the styles.
I've just got to copy it across now but am very hesitant.
This Style is based on subsilver2 and therefore you should use the /root/subsilver2 content.webslug wrote:Which folder should I copy into styles/twilightbb?
Have a look on the Source of your Board. If the Style is build by Tables, it is based on subsilver2.webslug wrote:How do I find out?
If it build by div boxes, it is based on prosilver.
No.webslug wrote:Also should I expect any graphical problems?
yeswebslug wrote: Is the Portal generally compatible with most themes?
I have installed this Theme too, and it works perfectly in Portal.
Well it installed without a hitch, very very seamless!
I am extremely impressed with this mod for phpbb 3.
I used it with version 3.04 with absolutely no problems.
10/10 Kudos to Mike and the rest of the team!
Keep up the good work.
