Uninstall portal
Uninstall portal
Boardlink: http://www.aussiefinchforum.net
Nothing I am trying to uninstall it
I have contact my host company and they said that they try to uninstall it and nothing work
How can I uninstall the portal I really want it gone of my forum
Re: Uninstall portal
Re-upload the install directory, navigate to the install page and click uninstall from the menu on the left.
May I ask why you want to uninstall the portal?
Hey Ice thanks for replying buddy
I want to uninstall it cause I am not sure on how to make it like change the colours of the tables and text to match my forum its all hard to do at the moment cause I am new to all of this and I am not good at coding stuff
And also its running up my disk space for some reason my disk space keeps going up by 100MBS everyday when I installed the forum
Its a great portal but when I get better at coding and stuff i will install it again
Strange, the portal on its own shouldn't increase space usage by anything more than a mb or 2. Are you sure it's not your users uploading attachments?
And about the colours - if you ask I'm sure someone can help you.
I have attachments disable on my forum so members can't post pictures Its not my forum putting up the space cause it never use to go up that high.
It didn't go up today which is good cause I don't want it to go up that high
And with the colour how can I make it match my theme its paron
For a start you need to use the subsilver2 not the prosilver template files.
- phpBB.de User: thomas.d
- phpBB.com User: thomas.d
No way, the portal consumes approx. 1,6 MB.AFF wrote:... And also its running up my disk space for some reason my disk space keeps going up by 100MBS everyday when I installed the forum ...
You mean, you loose 100 MB per day?AFF wrote:... for some reason my disk space keeps going up by 100MBS everyday when I installed the forum ...
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
Thomas
No it went yep 190 to 320 when i installed the portal I want it uninstall it
Don't worry I finally got it working and it matches my forum now and I am happy with it board 3 is great
I just want to know will it slow my forum down at all or not
Fine! Glad that it's working now!AFF wrote:Don't worry I finally got it working and it matches my forum now and I am happy with it board 3 is great
No, definately not!AFF wrote:I just want to know will it slow my forum down at all or not
Thomas
Thomas
Ok thank you for you reply
Hi how can I move the link to us box I want it to be under links here a picture to show you what I mean
Thanks
Thanks
Knowledge Base: Moving blocks / change order
Thomas
Thomas
Can i ask how you managed to get your custom style working?
Ive been trying for ages.
Im using the Arrow theme and ive been trying to make the portal mod fit in with this style.
Any help would be great.
I am not sure mate I had someone do it for me sorry
