[function.include]: failed to open stream
Kizo
Post by Kizo »
Your Portal Version: 1.0.2
Boardlink: http://kizozen.com
PHP Version: 3.0.x
I installed Board3Portal following the install instructions.
I have double checked all the install instructions to make sure I didn't miss anything.
when trying to run the /install_portal/install.php
I get the following
Warning: include(../common.php) [function.include]: failed to open stream: No such file or directory in /home/content/k/i/z/kizozen01/html/install_portal/install.php on line 29
Warning: include() [function.include]: Failed opening '../common.php' for inclusion (include_path='.:/usr/local/php5/lib/php') in /home/content/k/i/z/kizozen01/html/install_portal/install.php on line 29
Warning: include(../includes/acp/acp_modules.php) [function.include]: failed to open stream: No such file or directory in /home/content/k/i/z/kizozen01/html/install_portal/install.php on line 30
Warning: include() [function.include]: Failed opening '../includes/acp/acp_modules.php' for inclusion (include_path='.:/usr/local/php5/lib/php') in /home/content/k/i/z/kizozen01/html/install_portal/install.php on line 30
Fatal error: Call to a member function session_begin() on a non-object in /home/content/k/i/z/kizozen01/html/install_portal/install.php on line 32
[/i]
dragz
Re: [function.include]: failed to open stream
Post by dragz »
U sure u did it correctly ? cant see the index page
Kizo
Post by Kizo »
I fixed it. was clueless as to what directory they needed to be in so I put all the files in the website /./ instead of ./phpbb/
