Your Portal Version: 1.0.2
Boardlink: http://www.trommeforum.com/forum
Login and check all the files again
I get this error when I try to go to /install_portal/install.php:
PInUp Error
You must be logged in as an admin.
Go to login
I go to the index.php and login. Go back to this url and get the same message. But when I try to access http://www.trommeforum.com/forum I get this message:
SQL ERROR [ mysqli ]
Table 'trommeforum.trommeforumphpbb3_portal_config' doesn't exist [1146]
And yes, I have triplechecked that the constants.php is correct and I have purged the cache.
Problems with installation. SQL Error. Table doesn't exist.
Re: Problems with installation. SQL Error. Table doesn't exist.
Try this modified installer: download/file.php?id=130
Worked great! Thanks alot.
