Addon: guildox.com Guild Rankings
Addon Version: 1.0.2
Addon Author: Talonos
Addon Description: this block can display 3 images from guildox.com using your predefined settings. them 3 images have different infomation about your guilds progress within world of warcraft.
- Raid progress
- Raid achievements
- Battleground ranking
your guild a PVP guild but you want to display your battleground info ONLY? well thats possible as you can set it in the ACP to only display the images you require.
EXAMPLE:
25man raiding guild setup;
raid ranking = on
raid achievmenets = on
battleground rankings = off
having it that way will minimise the display abit and show just the info they want to show.
Addon Requirements: Board3 Portal 2.0.0b1 and newer.
Download Link is here:
http://pretereo-stormrage.co.uk/viewtopic.php?f=2&t=18
Instructions:
2. Add new module into left or right column of the portal (ACP > MODS > Portal > Portal Modules).
Demo: http://pretereo-stormrage.co.uk/portal.php Blocks on the Left are the current working Modules. others displayed there currently are not available yet unless stated
REVISION INFOMATION
1.0.2
Updated: now works with guildox's redesgined website. there is only 3 images available now as ranking are not ranked by group size anymore.Code: Select all
Updated to include FLEX raid progressCode: Select all
Initial Release
