1: The background to the module is blue, and I need it transparent or white
2: This member is a Junior Administrator, not a Moderator, and is specified as such in the ACP as her default group. I did find this topic, which states how to fix this, I believe, but after following instructions, nothing has changed.
3: The color of the module's outline is black on top, and blue on the bottom. I need for the entire thing to be outlined in black.
My next issue:
There is no portal tab. Now, this was installed with AutoMod, but I went back through the install.xml when I saw no tab for the portal to ensure that everything installed properly, which it did. The style I'm using, if that helps, is IDLaunch Black, phpbb3 version 3.0.10.
How to fix these? Thank you!
