I have some questions before I try the install/update.
I am running :
MOD Version Check - Board3 Portal is up to date
Current Version 1.0.6
Latest Version 1.0.6
My questions are:
- Im also running the theme you helped me with called "ca_black", so would like to know if this theme will work on 2.0.0b1? So I just would like to know if themes that worked on 1.0.6 will work on 2.0.0b1 ?
 - This statement I find interesting - "Unlimited custom blocks - you can add as many custom blocks in the ACP as you want". Does this allow where to position the new blocks as well? For example, left, right or middle, or do we have to manually code the blocks in the template where we want the additional custom blocks to be put?
