How can you tell a theme is based off of prosilver?
SliXie
phpBB.de User: SliXie
phpBB.com User: slixie
Post by SliXie »
Your Portal Version: 1.0.6
It's more just a general question how can you tell if a theme is based off of prosilver? i'm realising now as i code, that prosilver based themes are much better than subsilver based themes.
Re: How can you tell a theme is based off of prosilver?
You have to open the Install instructions.
Then you can see it.
viewforum.php?f=47
Take a look at phpbb3styles.net. If you look at the demo of a style, it will also show on what style it is based right next to the style name.
Return to “Styles Support”
