Your Portal Version: 1.05
Boardlink: http://www.s3xyclan.com/main/phpBB3/portal.php
Searched every css a for some sort of reference on changing the size of forum and portal width.
Come here
So the board 3 tab in the acp shows I can change the left and right columns. I want to change the entire width of the page so it fills the browser properly. For the life of me I cant find it in this style.
I got the style from http://www.phpbb3styles.net/db/style/DVGFX
Last post i made you guys refused to look at it because of copyright information? I have not removed anything from the style and you can download and look at it yourself. Obviously i'm not the talented if I am here begging for help to increased the width of my page.
Change width of portal and board index
Re: Change width of portal and board index
Hi,Span wrote: Last post i made you guys refused to look at it because of copyright information? I have not removed anything from the style and you can download and look at it yourself. Obviously i'm not the talented if I am here begging for help to increased the width of my page.[/i]
so you see what I mean:
at the lower edge of your page:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
<div class="copyright">Powered by <a href="http://www.phpbb.com/">phpBB</a> © 2000, 2002, 2005, 2007 phpBB Group
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group | DVGFX by: Matt
<div class="copyright">Powered by <a href="http://www.phpbb.com/">phpBB</a> © 2000, 2002, 2005, 2007 phpBB Group | DVGFX by: <a href="http://dvgfx.blogspot.com">Matt</a>
- phpBB.de User: spanspace
- phpBB.com User: spanspace
Ok it's there. For the record it was not in the skin I downloaded on the site I provided above. Please don't think I removed it. Let's get down to business. I'd really appreciate your expertise on fixing the two support tickets I put in. Thanks in advance.
Change width of portal and board index for Style DVGFX
try using this for Style DVGFX:
open: root/styles/DVGFX/theme/common.css
max-width: 1000px;
max-width: 95%;
I did it. I am behind a firewall at work. So I can't see the change until I get home. I'll let you know if I everything is good once I can get home and look at it. Thanks.
