Installed phpbb3 3.0.7, Board3 1.0.5 and style CA_Black - works ok.
Then installed Portalview v1.0.0RC3 plus all edits - Works ok with sub and prosilver
I made the same edits and copied in all the extra files into the CA_Black template folder as per prosliver instructions.
When I click on the forum index link I get the forum index at the top of the screan in full width, and all the portal blocks and squashed up and messed up right at the bottom of the page.
The CA_Black files differ somewhat from the prosilver files so when making the edits I just put them in what looked to be same places as they where made in prosilver.
This is on a development local board so I cant link to it im afraid, but can post code and printscreens if/as needed
Thanks in advanced for any and all help
Slysi
