Your phpBB Type: Standard version: 3.0.6
Boardlink: http://www.witvisforum.nl
Link of the stijl http://wp.christianbullock.com/absolution-phpbb3-style/
Style that I have is Absolution. The style is based on prosilver.
Hello,
I have a probleme with my block_config.html
If you look at my forum you will see what the problem is wiht this block_config.html
Can somebody look to this block_config.html and tell what's wrong is.
Thanks a lot and sorry for my bad english.
Pascal
Block_config.html
<!--version $Id: _block_config.html v1.0.5 adapted by: Mike $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<div class="inner"><ul class="topiclist"><li class="header"><div class="custom-cat-header" style="width:100%"><dl class="icon">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</dl></div></li></ul><div class="custom-row">' -->
<!-- DEFINE $LR_BLOCK_F_R = '</div><div class="custom-foot"></div><br style="clear:both" />' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="inner"><ul class="topiclist"><li class="header"><div class="custom-cat-header"><dl class="icon">' -->
<!-- DEFINE $C_BLOCK_H_R = '</dl></div></li></ul><div class="custom-row">' -->
<!-- DEFINE $C_BLOCK_F_R = '</div><div class="custom-foot"></div><br style="clear:both" />' -->
