Your Portal Version: 1.0.4
Boardlink: http://jahspell.interhost.co.il
Style Demo: Skyblue
Phpbb 3.0.5 with the following MODs installed:
- Reimg (according to install.xml)
- Quick Reply (according to install.xml)
- Notify Admin on new user registration
some code changes according to this how-to:
http://www.phpbb.com/kb/article/links-o ... w-windows/
attempted to apply some code changes for announcements.html...
The issue is ---> a frame of Announcement block is not continuous.
Using Compact Announcement block solve the problem.
Issue is browser related:
On IE8 is not observed
Occurs on the following browsers:
- Firefox last version
- Chrome last version
- Opera last version
By the way, the installation is in russian.
Thank you.
Skyblue style Announcement block issue
Re: Skyblue style Announcement block issue
OK... that's sort of weird...
Please try this:
open your _block_config.htm
find:
set it to "0":
purge caches after that
I hope it will work, cause i didnt know anything else you can do...
Please try this:
find:
<!-- DEFINE $S_POSTBODY_TOP = 0 -->
- phpBB.com User: jahspell
Great work.
Thank you.
Thank you.
