Your Portal Version: 1.0.2
does not apply
does not apply
First I really appreciate board3portal.
I saw the release of 1.0.4 here at Board3portal, but the release on phpbb is 1.0.2.
Q. Why doesn't the latest release batch at both sites?
Q. Is 1.0.4 a stable release?
Q. I am using 1.0.2, and have had to put in a few edits. What is the best procedure to upgrade?
Thanks again, for your great mod. My forum now is not just a forum but a nice looking website, thanks to Board3portal.
p.s.
I have a question posted lower about getting phpbb username and passing it to javascript running out of a portal block.
Release 1.0.4 at B3portal, but not at phpbb?
Re: Release 1.0.4 at B3portal, but not at phpbb?
There has to be an validation before any new Release on phpbb.com, but this is a protracted treatmentyocalif wrote:Q. Why doesn't the latest release batch at both sites?
Our Testing Team says "YES" ...yocalif wrote:Q. Is 1.0.4 a stable release?
Thats the reason why you should alway update to the latest versionyocalif wrote:Q. I am using 1.0.2, and have had to put in a few edits. What is the best procedure to upgrade?
If you first update to 1.0.3 and after that to 1.0.4 you have update instructions for all the steps included in the package.
1.0.2 -> 1.0.4 isnt an inherent part of the latest version...
- phpBB.de User: Delorian
- phpBB.com User: Delorian
All, I might have missed something, but when I tried install portal 1.0.4 today, I get the following error.
General Error
SQL ERROR [ mssql_odbc ]
[Microsoft][SQL Server Native Client 10.0][SQL Server]Incorrect syntax near the keyword 'IF'. [37000]
SQL
DROP TABLE IF EXISTS phpbb_portal_config
BACKTRACE
FILE: includes/db/mssql_odbc.php
LINE: 165
CALL: dbal->sql_error()
FILE: install/install_functions.php
LINE: 160
CALL: dbal_mssql_odbc->sql_query()
LINE: 125
CALL: b3p_drop_table()
FILE: install/install_install.php
LINE: 115
CALL: b3p_create_table()
LINE: 73
CALL: install_install->load_schema()
FILE: install/index.php
LINE: 279
CALL: install_install->main()
LINE: 56
CALL: module->load()
By the way, I'm using SQL 2008.
Any help would be great.
Thanks,
Delorian
General Error
SQL
BACKTRACE
LINE: 165
LINE: 160
LINE: 125
LINE: 115
LINE: 73
LINE: 279
LINE: 56
Thanks,
Delorian
