Boardlink: http://vwarrior.legitclansunited.co.cc/phpbb/index.php
This is a install issue... regarding overall_header.html and the getaway style
After editing the Getaway overall_header.html, the portal/index and time date row is appearing below the forums not above.
editing the getaway overall_header.html but it doesn't match subsilver2. Result the "portal/index" and time date row is appearing below the forums. I tried several different edits none work. I then used a stock getaway overall_header.html and it appears the portal and forums are loading and working fine??
This strange since there are so many edits required in the overall_header.html, to work with any edits is strange.
Using style Getaway (based on subsilver2).
The overall_header.html for Getaway doesn't match the subsilver2 overall_header.html.
After attempting to edit the overall_header.html, I ran it.
It appears to be working with one exception. The "portal/Board Index" and Time/Date row is not above the forums, instead it is below.
I tried several different edits but none worked.
I then used a stock unedited Getaway overall_header.html, and the board works fine.
I am not sure why, it is strange.
Why would the stock overall_header.html work?
However I am scared to go any further with the stock overall_header.html, as it might lead to problems down the road.
What would be the edits for Getaway's overall_header.html
thanks
editing overall_header.html in Getaway
Re: editing overall_header.html in Getaway
Courtesy of Vjacheslav Trushkin the author of Getaway & Getaway Green.
PS, nice to see all the helpful responses....
1. add before
2. add before
3. add after
4. add before
5. add before
6. add at the end of file
1. add before
<div class="navrow">
2. add before
<div id="contentrow">
3. add after
4. add before
5. add before
