Boardlink: http://www.yfchost.com/home/
Installed the portal and customized the menu. Also, because I am using a different style, I had to change a couple of the style modification instructions from install.xml
Looked through the style sheet.
It took some work, but I had to manually change the style for the portal to "integrate" into my site. I am not using the default prosilver style, so none of the install instructions matched with my style. All I did manually is add menu links (not the problem). The theme I am using stores all of it's CSS information in one file, unlike the standard prosilver template. So, i'm not really sure how to add this code to the file: @import url("portal.css"); , as I am not experienced with CSS files. If you could help me out with this, that would be great. The upload option does not seem to be here, or I would upload the .css of the template that I am using to show you.
Thanks,
Chris
Style of Center Blocks
Re: Style of Center Blocks
Just put it at the end of your CSS-file.
I did, it seems to miss the center blocks. Can you take a look at the forum site?
I just re-uploaded my portal.css file and my stylesheet.css file to have a fresh start. I then made the change from install.xml. Now nothing seems to have any "style" on the portal.
You need to refresh your theme cache.
That did not work.
It seems your style is based on subsilver2, therefore you need to do the subsilver2 edits and use the subsilver2 files.
I will try that and post back. Also, thank-you for all your help
That did the trick!!! Thank-you Very much!
