Kind time of days. I live in Russia. Unfortunately I know English language badly. Therefore I am sorry if it is badly written.
I have forum PHPBB3 3.0.5, I have put on it Board3. All works perfectly, but I have changed a subject on Aero Blue and I do not have link above Portal. I assume that I should edit a file overall_header, but I do not know what to insert.
That I did: I have established PHPBB3, then Board3,
Adapted under style prosilver. Here all was good. Then I have established style AeroBlue, have then copied B3P_AeroBlue in catalogue AeroBlue, at the given stage all works well, besides, that there is no link Portal and I cannot come back from the Forum to the Portal.
Please help, or give the reference to detailed installation of this style. Yours faithfully Michael
It is my overall_header
<head>
{META}
// <![CDATA[
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
popup('{UA_POPUP_PM}', 480, 180, '_phpbbprivmsg');
if (!name)
name = '_popup';
return false;
function jumpto()
var per_page = '{PER_PAGE}';
* Find a member
function find_username(url)
popup(url, 870, 570, '_usersearch');
return false;
* Mark/unmark checklist
if (!parent)
if (!parent)
return;
rb[r].checked = state;
<!-- IF ._file -->
function play_qt_file(obj)
if (rectangle)
var width = 200;
var height = 0;
obj.width = width;
obj.height = height + 16;
obj.Play();
function selectCode(a)
// Get ID of code block
var e = a.parentNode.parentNode.getElementsByTagName('CODE')[0];
// Not IE
if (window.getSelection)
var s = window.getSelection();
// Safari
if (s.setBaseAndExtent)
s.setBaseAndExtent(e, 0, e, e.innerText.length - 1);
// Firefox and Opera
var r = document.createRange();
r.selectNodeContents(e);
s.removeAllRanges();
s.addRange(r);
// Some older browsers
else if (document.getSelection)
var s = document.getSelection();
s.addRange(r);
// IE
else if (document.selection)
var r = document.body.createTextRange();
r.moveToElementText(e);
r.select();
</script>
</head>
<a name="top"></a>
<table class="wrap" width="100%" cellpadding="0" cellspacing="0">
<tr><td>
<div id="wrapheader">
<td width="18" height="18"><img src="{T_THEME_PATH}/images/tl.png" width="18" height="18" alt="" /></td>
<td height="18" style="background:url('{T_THEME_PATH}/images/tm.png');"></td>
<td width="18" height="18"><img src="{T_THEME_PATH}/images/tr.png" width="18" height="18" alt="" /></td>
<td width="18" style="background:url('{T_THEME_PATH}/images/ml.png');"></td>
<td>
<table width="100%" border="0" align="center" cellpadding="0" cellspacing="0">
<td width="303" height="80" style="background:url('{T_THEME_PATH}/images/midl.png');"><div class="logo"><a class="headw" href="{U_INDEX}">{SITENAME}</a><br /><span class="genmedw">{SITE_DESCRIPTION}</span></div></td>
<td height="80" style="background:url('{T_THEME_PATH}/images/midm.png');"> </td>
<td width="470" height="80" align="right" valign="top" style="background:url('{T_THEME_PATH}/images/midr.png');">
<div class="midlink">
<div id="search-box">
<fieldset class="nb">
<input name="keywords" style="opacity:0.8;filter:alpha(opacity=80)" onmouseover="this.style.opacity=1;this.filters.alpha.opacity=100" onmouseout="this.style.opacity=0.8;this.filters.alpha.opacity=80" type="text" class="inputbox search" id="keywords" title="{L_SEARCH_KEYWORDS}" onblur="if(this.value=='')this.value='{LA_SEARCH_MINI}';" onclick="if(this.value=='{LA_SEARCH_MINI}')this.value='';" value="<!-- IF SEARCH_WORDS-->{SEARCH_WORDS}<!-- ELSE -->{L_SEARCH_MINI}<!-- ENDIF -->" maxlength="50" />
<input class="nb" name="submit" type="image" src="{T_THEME_PATH}/images/search.png" align="absmiddle" /><br />
<a class="genmedw" href="{U_SEARCH}" title="{L_SEARCH_ADV_EXPLAIN}">{L_SEARCH_ADV}</a> {S_SEARCH_HIDDEN_FIELDS}
</fieldset>
</form>
<td height="24" align="left" style="background:url('{T_THEME_PATH}/images/bottomm.png');">
<div class="buttonwrapper">
<div class="navspacel"></div>
<!-- IF S_USER_LOGGED_IN -->
<!-- ELSEIF S_REGISTER_ENABLED -->
<a class="squarebuttonl" href="{U_REGISTER}"><span>{L_REGISTER}</span></a><div class="navspacel"></div>
<a class="squarebuttonl" href="{U_PROFILE}"><span>{L_PROFILE}</span></a><div class="navspacel"></div>
<!-- IF S_DISPLAY_PM -->
<a class="squarebuttonl" href="{U_PRIVATEMSGS}"><span>{PRIVATE_MESSAGE_INFO}</span></a><div class="navspacel"></div>
<a class="squarebuttonl" href="{U_RESTORE_PERMISSIONS}"><span>{L_RESTORE_PERMISSIONS}</span></a>
<td width="431" height="24" align="right" style="background:url('{T_THEME_PATH}/images/bottomr.png');">
<div class="navspacer"></div>
<!-- IF not S_IS_BOT -->
<a class="squarebuttonr" href="{U_LOGIN_LOGOUT}"><span>{L_LOGIN_LOGOUT}</span></a><div class="navspacer"></div>
<a class="squarebuttonr" href="{U_MEMBERLIST}"><span>{L_MEMBERLIST}</span></a><div class="navspacer"></div>
<a class="squarebuttonr" href="{U_FAQ}"><span>{L_FAQ}</span></a>
<td width="18" style="background:url('{T_THEME_PATH}/images/mr.png');"></td>
<td width="18" height="18" align="right"><img src="{T_THEME_PATH}/images/bl.png" width="18" height="18" alt="" /></td>
<td height="18" style="background:url('{T_THEME_PATH}/images/bm.png');"></td>
<td width="18" height="18"><img src="{T_THEME_PATH}/images/br.png" width="18" height="18" alt="" /></td>
<div id="datebar">
<!-- IF S_BOARD_DISABLED -->
<tr><td class="gensmall">
<span class="error">{L_BOARD_DISABLED}</span>
</td></tr>
<!-- IF S_DISPLAY_SEARCH -->
<p class="searchbar">
</p>
<br style="clear: both;" />
