Can order of blocks be changed and other ?'s
pmlabrier
phpBB.de User: pmlabrier
phpBB.com User: pmlabrier
Post by pmlabrier »
Boardlink: http://www.cardclubs.net
Fresh install of phpbb3 and portal
Is it possible to designate what spot a block will display in? I would like to change which order they appear in
Also, can you specify which groups see a block? I would like to specify a block NOT appear to registered users.
Paul
Re: Can order of blocks be changed and other ?'s
Knowledge Base: Moving blocks / change order
pmlabrier wrote:Also, can you specify which groups see a block? I would like to specify a block NOT appear to registered users.
Please use the search function, this question has been answered a few times.
