Your Portal Version: 2.0.0
Boardlink: http://forumdematematica.org/
MySQL Version: 5.5.23-55
I installed the portal
I ran the board3 script again, the php file which is on install folder
I purged chache
I refreshed all styles on all options (Images, Themes, etc..)
My active style is subsilver2
I've already made the subsilver2 style modifications, I've made the DIY instructions, but when I go to ACP to edit the blocks I get this error in Red:
File not found: styles/serenitydarkblue/theme/images/portal/portal_menu.png
Even when I go to ACP->MOD->General Configurations and I change some values, when I press OK/send, I get an error in Red:
file not found: styles/serenitydarkblue/theme/images/portal/
It seems he's trying to get serenitydarkblue style, but my active astyle is subsilver2
What might be?
Please anyone...
Thank you so much
Style subsilver2
joao_pimentel
- phpBB.com User: joao_pimentel
joao_pimentel
Re: Style subsilver2
The problem is solved
It seems I need to have all the portal files for all styles installed, otherwise it will give an error
Cheers from Lisbon
Cheers from Lisbon
noth
- phpBB.com User: noth
subSilver2 style in board3 is gorgeous, very good work by Marc
