Hi all,
What I am looking to achieve is create a custom block so to speak, which I can add in the xml code to. This will then display the Headline and a few lines of a couple of news feeds onto our portal.
For example, we have a Steamgroups, which we use to show updates/annoucements on. Rather than having to update both the forums and steamgroup, I think it would be good if a small block could show some of the rss feeds from the steamgroup in a small block. I hope you see and understand what I mean.
Does anyone have any thoughts or ideas if this is possible? I dont want to rss feed our forums content, I want the forum portal to show feeds from other sites, such as steam or whatever...
Ive tried adding in hard code into the custom block and also creating a iframe showing the address of the rss feed xlm file, but this doesnt work either.
I was wondering if this would be best to use, or if there is a simpler solution available... http://www.rssinclude.com/my_rssboxes/e ... &tab=feeds
Any help would be great.
IXL
RSS Display for Portal Board 3
Re: RSS Display for Portal Board 3
You can add this bbcode and displayed that.
http://www.phpbb3bbcodes.com/viewtopic. ... 9d463bb699
Topic author - Sponsor
- phpBB.de User: IXL
- phpBB.com User: IXLUKCOM
Thanks for that.
Last night I found a solution I think that seems to do well.
I am using http://www.blastcasta.com/add-news-to-your-website.aspx and im pasting the final code into the board3's small custom block. So far, it seems great.
The problem now is I need to make another ( a second ) small custom block because im already using the small one for something else... lol So thats something else im going to have to figure out how to make.
IXL
IXL
