Problem with point in menu
Corw
Post by Corw »
Your Portal Version: 1.0.4
Hello,
Not because me the point appears out of the block of the menu, in the 2.
It is possible to estimate in the photos.
Thank you very much for the help.
http://img18.imageshack.us/img18/8624/holato.jpg
Re: Problem with point in menu
This is caused by one of the following reasons:
- you forget to include portal.css into stylesheet.css
- you forget to upload portal.css
- you forget to clear all caches after you doing the first point.
JezUK1
phpBB.com User: JezUK1
Post by JezUK1 »
What do you mean include portal.css into stylesheet.css?
Jez
OneLifeBoard.com - We Discuss & exchange information and advice on topics that matter to you!
GardenWildlife.co.uk - For all your wildlife needs, view nesting birds live & talk to others on the online message boards.
Read install.xml regarding stylesheet.css
There is written down what to do.
JezUK1
Post by JezUK1 »
But I have done this
pen: styles/prosilver/theme/stylesheet.css
CODE:SELECT ALL
CODE:SELECT ALL
I have done everything to the book. I have checked and checked again. But yet I still cant sort it out... Please can you help? My site is at www.onelifeboard.com
Jez
MyLady
Sponsor
phpBB.de User: Scanialady
phpBB.com User: Scanialady
Post by MyLady »
I have the same problem after updating style Bl@ck.
Ich habe das selbe Problem nach dem Update von Portal und Style bei dem Style Bl@ck (der mit der vorigen Version die Punkte NICHT zeigt, sondern Pfeile), bei Prosilver dagegen ist alles ok. Es scheint am Style zu liegen - nur weiß ich nicht wo ich suche soll. Portal.css ist hochgeladen und in stylesheet.css eingebunden.
diese Woche durchgeführte Updates: portal 1.0.4, phpbb 3.0.6, gallery 1.0.3, gallery block 1.4.1, styles Bl@ck und Chrimbo (prosilver und subsilver zusammen mit phpBB)
edit://
problem solved after clearing cache-folder on ftp directly and purge cache, templates and them again.
nach mehrfachem leeren des Caches und aktualisieren der Templates habe ich den Cache-Ordner auf dem FTP geleert. Nun ist es ok.
JezUK1
Post by JezUK1 »
I have removed the stuff from the ftp and did you what said but still no joy :(
Jez
JezUK1
Post by JezUK1 »
I tell a lie it did work.. Thanks for the tip ;)
Jez
spaceman
phpBB.de User: spaceman
phpBB.com User: spaceman
Post by spaceman »
The solutions to this problem seemed elementary so I was gutted when they failed.
Then I tried Ctrl-F5 (to force a page refresh) on the portal page and remembered that the browser has a cache too. :roll: Worth remembering before you make a post in this thread :mrgreen:
Return to “Styles Support”
