Boardlink: http://crimson.byou-shin.com/
Hey guys I just installed Board3 and everything works but the portal looks a bit weird.
I'm using a subsilver2 based theme and followed everything correctly except for the subsilver2 overall_header instructions.
I couldn't find the line of code it wanted for a couple lines so I guessed where it should have gone, but it seems to have come out weird.
Here's the link to my overall_header.html - http://www.mediafire.com/?4whgyklnowa
Thanks.
Help with Header
- Valued Contributor
- phpBB.de User: MB34
Re: Help with Header
After just a cursor inspection, try this:
swap these two lines:
to look like this:
Move the
at line 166 to after
on line 190
What is your Style name?
EDIT:
Ah, ha, DarkFantasy. Did you download it from here:
http://www.board3-styles.de/b3p_102/DarkFantasy.zip
EDIT2:
Should look like this:
http://area51.mikevil.de/portal.php?sty ... de8ae0bca7
<a href="{U_INDEX}">{SITE_LOGO_IMG}</a>
<br style="clear: both;" /><br />
EDIT:
EDIT2:
Reason: merged postings (please avoid double/tribble postings)
MrBaseball34
Hook 'em Horns
2005 College Football National Champions
2005 College Baseball National Champions
Hook 'em Horns
You can use my header if you dont have moded yours already:
<head>
{META}
<!--[if IE]><link rel="stylesheet" href="{T_THEME_PATH}/ie.css" type="text/css" /><![endif]-->
<!--[if lte IE 6]>
<script defer type="text/javascript" src="{T_TEMPLATE_PATH}/pngfix.js"></script>
<link rel="stylesheet" href="{T_THEME_PATH}/ie6.css" type="text/css" />
<![endif]-->
// <![CDATA[
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
if (!name)
name = '_popup';
return false;
function jumpto()
var perpage = '{PER_PAGE}';
* Find a member
function find_username(url)
return false;
* Mark/unmark checklist
if (!parent)
if (!parent)
return;
rb[r].checked = state;
<!-- IF ._file -->
function play_qt_file(obj)
if (rectangle)
var width = 200;
var height = 0;
obj.width = width;
obj.height = height + 16;
obj.Play();
</script>
</head>
<a name="top"></a>
<div id="container">
<div id="wrapper">
<div id="header">
<div id="top_menu">
<!-- IF S_DISPLAY_SEARCH --><a id="search" href="{U_SEARCH}">{L_SEARCH}</a><!-- ENDIF -->
<!-- IF not S_IS_BOT --><!-- IF S_DISPLAY_MEMBERLIST --><a id="members" href="{U_MEMBERLIST}">{L_MEMBERLIST}</a><!-- ENDIF -->
<!-- IF S_USER_LOGGED_IN --><a id="ucp" href="{U_PROFILE}">{L_PROFILE}</a><!-- ENDIF --><!-- ENDIF -->
<a id="faq" href="{U_FAQ}">{L_FAQ}</a>
<div id="content1">
<div id="content2">
<div id="content3">
<p class="genmed"><!-- IF not S_IS_BOT --><a href="{U_LOGIN_LOGOUT}"><b>{L_LOGIN_LOGOUT}</b></a><!-- ENDIF -->
<!-- IF S_DISPLAY_PM --> | <a href="{U_PRIVATEMSGS}"><b>{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></b></a><!-- ENDIF -->
<!-- ELSEIF S_REGISTER_ENABLED --> | <a href="{U_REGISTER}"><b>{L_REGISTER}</b></a>
<!-- IF U_RESTORE_PERMISSIONS --><br /><a href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a><!-- ENDIF -->
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN --><br /><span style="color: red;">{L_BOARD_DISABLED}</span><!-- ENDIF -->
</p>
<p class="searchbar">
</p>
No problem Mike. I didn't see it until after I'd already posted the other post and didn't think to edit the first one.Reason: merged postings (please avoid double/tribble postings)
BTW, should be trebble or triple .vs tribble (tribbles are the little furry creatures in Star Trek, remember?)
MrBaseball34
Hook 'em Horns
Hook 'em Horns
Thanks alot everyone! It's working!
lol... thanx Mrbaseball... it happens if you try to answer too much questions in too little time
