analouge clock
analouge clock
how do i get an analouge clock instead of the digi one ?
- Valued Contributor
- phpBB.de User: HenK
- phpBB.com User: H3nK
Re: analouge clock
You can download several flash clocks from here, for example:
http://www.123php.de/themen/flash/index.htm
sorry, it's a german site:)
You only have to rename the swf file and upload it into root/portal/images/.
- phpBB.de User: thomas.d
- phpBB.com User: thomas.d
Re: analouge clock
The name of the file has to be clock.swfHenK wrote:... You only have to rename the swf file and upload it into root/portal/images/.
Additionally you may have to edit /styles/*your_style*/template/portal/block/clock.html with the appropriate "width"- and "height"-attributes.
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
Thomas
Re: analouge clock
thanks.............
Re: analouge clock
me also put analog clock at my phpbb3 portal
what i do is only edit .../styles/styles_name/template/portal/block/clock.html
replace current code for clock to new html code
i get my flash clock from here -> http://www.worldtimeserver.com/clocks/
also you can google for site that offer free html/java code for clock
if you don't want your clock from external link, maybe if that website going down, your clock also not appear, so you can replace clock.swf in ..../root/portal/images/clock.swf
Re: analouge clock
I am looking for one that does not have a gaudy look about it ... I dont like the big bold side walls on them and if anyone knows where I can get one that is clean and simple could they please post a link to it thanks.
Re: analouge clock
Thanks for that link PeterS as I managed to find a clock there that suits my theme perfectly and that is not easy to do.
