Boardlink: http://www.ronnie-james-dio.com/RJDtesting/portal.php
PHP Version: 5
Fresh install
Changed the size in the ACP
How can I get the blocks on the left and right sides to adjust smaller
Their default is 180 and upon measuring them, they seem to be somewhat bigger
Also...I se the left side to 150 and it does noting at all and it would look much better to be smaller in width
Any ideas please?
Block size width
DragonMaster
- phpBB.com User: DragonMaster1
Re: Block size width
if you have something in the box content that prevents to lower the size to less than 180 px (I think this clock for instance).
DragonMaster
I turned off the clock block and it still won’t get any smaller
Currently set to 100 and us way too big
As i see in you source code the left column is set to 100px and the right is set to 180px. And the left one is thinner.
Anyway, your source code looks fine, it should work. Try to find out which element is blocking it from getting thinner.
Tip: the mini calendar is a typical element which is causing trouble to get it thinner. Deactivate it for getting the right column thinner.
hm - what about the attachments - i am not quite sure. But i could imagine that the title of the attachment can cause this. At the moment i dont see another thing than something in the box content.
DragonMaster
Turned off the attachments also and still the same
Also cleared cache and refreshed template & imageset
DragonMaster
Found it
I had a long link in the extra links box and even though it broke to the next line, it was stretching the block to where it would not get smaller
I need to experiment with that
Thanx for the help
Thanx for the help
btw - Ronnie James Dio - do you know the "tributes" to him by Tenacious D?
Link
And after that song he appeared in this song, from the actual album:
Link
So he must have a sense of humor.
Sorry for OT.
Link
Link
Sorry for OT.
DragonMaster
Oh yes....I loaded those a while back
RJD has the best voice in rock
I have a bunch of videos on my personal web site:
http://tinyurl.com/bovxec
Great 4 part interview I added yesterday on the main board:
http://www.ronnie-james-dio.com/RJD/vie ... =33&t=2144
